LED swap over! | Page 2 | Ford Explorer Forums
LED swap over!
Ok someone please tell me if there 1998/99-2001 back doors light up? The switches I mean. Mine don't even have the factory wires for the lights! There is NO way I am running power wires back there!:salute:
Mine is the same way. Someone here suggested cutting the connectors off of harnesses at a junkyard and slipping them into the switch plug. Then, you can just connect to the power and ground for the window.
Keep in mind if you do go this route the light will be on all the time and not just with the headlights, they will not dim with the dimmer wheel, and will go off when the window lockout is engaged.
If I was going to do that I would splice into the driver door switch light power and run it where need be. But I'm not worried about it.
looks great danny
Tim has the new MC switch done and on its way. So I should have it in a month! Takes 3 weeks for me to get **** from canada!
Hey Tim I got the MCS in today and it rocks! Two of the LEDs are alittle dodgy but I seam to have got them working ok :) Thanks a lot!
Thanks for sharing......:confused:
