SB98UKexplorer
- February 27, 2008
- UK croydon
- 98 explorer 4.0 SOHC v6
iv replaced the normal bulbs for color LED as the warning lights on the speedo clocks iv pruchased are clear guages that havnt got color to give for the warning lights, problem is after replacing the bulb for the led on the battery sign its always on when you put the key in is always on after starting with a faint power lighting it, same for the 4x4 lights etc, except my indecator/ handbrake and headlights that go off properly, what can i do to make them power off properly in there normal use?
