Left side Door problem | Ford Explorer Forums
benitomce
México
Ford Explorer 97'
Hey guys, first of all, sorry for my english, well, i coming to this forum to ask about one problem that i have with an explorer 93, the problem is this: the front left side door does not open, the problem come when i get down and close the door, then when i come back and try to open it, it doesn't open, i pull of the lever from outside and the lock don't unlock, then i try it from inside and i got the same. Well this is my problem, i will be so grateful if you can solve this :D. If you can bring me the diagrams of the door it might be useful.
Thanks.
(¿Alguien que hable español?)
You need to remove your inner door panel and check and adjust the linkages. You may need to bend a rod to take up some of the slack.
