Left Turn Signal wiring? | Ford Explorer Forums - Serious Explorations
JLook95
Seattle, WA
1999 Explorer Sport
My left turn signal start wigging out. It started out with clicking noises in the steering column, like a bad relay or something. The the signal would stick on all the time. I was able to occasionally reset it by pulling and replacing the 20 Amp fuse, but it eventually became a permanent thing. I then replaced the turn signal relay under the dash (at $38) thinking that relay was bad, as it seemed that that is where the clicking noise was coming from. No luck. I finally gave up and took it into the Ford dealership and they replaced wiring in the actual steering column where the signal switch connects in the column. This was a $200 job. Anyone have problems like this with their late models?
