D
Deleted member 352605
My 98 4.0 Sohc has made it 340k, but now the cassettes are making noise... it has gone about 30k without the speedo and odo because it stops in heat...
Do some research on preoilersMy 98 4.0 Sohc has made it 340k, but now the cassettes are making noise... it has gone about 30k without the speedo and odo because it stops in heat...
I have had my v8 for close to 9 years now and never read much about that wonderful piece of art from Ford called 4.0 SOHC. Now, that I got also 07 with v6 now with 116k miles, I need to get educated.
Can you guys post the highest mileage you squeezed out of the v6 before the timing issues ?
What is the most common failure on those ? Do I need to pull the motor out to do the rear cassette ? Are the guides the main problem ? I watched a video where the plastic pieces of guides fell down and blocked the oil pump and starved the engine of oil. Anything else I need to know about the ?
Tech by Trade - I hope for you to chime in (seriously).
Thanks
194858and I'm ready to pull the engine outI have had my v8 for close to 9 years now and never read much about that wonderful piece of art from Ford called 4.0 SOHC. Now, that I got also 07 with v6 now with 116k miles, I need to get educated.
Thanks
Hi I just bought a Land Rover 2006 discovery factory fitted with a Ford 4L V6 the motor was in a bad way both Frount and back timing chain tensioners had disinterested the Frount chain had taken out the chain tensioner and the timing chain had worn through the plastic tappet cover we also replaced six bent inlet valves and the right hand side camshaft the motor had done 313000kms. My 2007 Currier 4x4 truck is fitted with the same motor an has done 210000kms and I will be replacing the timing chains, cassettes, and tensioners with a Malling set in the very near future.I have had my v8 for close to 9 years now and never read much about that wonderful piece of art from Ford called 4.0 SOHC. Now, that I got also 07 with v6 now with 116k miles, I need to get educated.
Thanks
I got 236000 on my 2002 4.0 sohc sportrack and it stumbled about 2 weeks ago.Since I can't afford a good code reader ( I tried a 35 doll on fe but to me it gave nothing .I had an old manual and tested cam sensor it showed bad do replaced it fuel filter never had changed so I went an did but nothing h e lpedso since the tach isn't moving I went and changed sparkpmugs and crank sensor2003 V6 - just hit 180k with no engine failures. This engine still runs great and doesn't have any sign of dying at this point.
2008 V6 - just hit 100k with no engine failures.
*Both engines have had the radiator replaced and thermostat housing replaced due to leaks.
I have a 1994 Ford Explorer with a 4.0 V6. I purchased it used in 2010 with almost 200,000 miles on it. Had to rebuild all four power window motors do little tubes that go in there. Put a radiator in it two water pumps. Upper and lower hoses two batteries since then brakes. Power steering hoses. But I have yet to take the motor apart except for installing a new thermostat and I just crossed 400,000 miles to be precise 400337 miles. It goes through about 1 quart of oil a week but to me that is still cheaper than buying a used motor and putting it in or buying a rebuilt motor and putting it in I would like to see 500,000 miles then take a picture of my odometer and send it to Ford I love this engineI have had my v8 for close to 9 years now and never read much about that wonderful piece of art from Ford called 4.0 SOHC. Now, that I got also 07 with v6 now with 116k miles, I need to get educated.
Thanks
HiI have had my v8 for close to 9 years now and never read much about that wonderful piece of art from Ford called 4.0 SOHC. Now, that I got also 07 with v6 now with 116k miles, I need to get educated.
Thanks
hi I pulled my v6 down when the head gasket blew on myI have had my v8 for close to 9 years now and never read much about that wonderful piece of art from Ford called 4.0 SOHC. Now, that I got also 07 with v6 now with 116k miles, I need to get educated.
Thanks
Thanks
Hi it’s not as difficult as it looks I pulled my V6 2007 Ford Currier engine down to replace the blown head gasket and was able to time the motor without the timing tools, there are YouTube sites you can go to to see how it’s done the truck has done 200ks now and I will be replacing the timing chains from a reputable company like Melleng. I have a just acquired a 2006 Land Rover discovery V6 with a blown motor the motor had done 314ks before the timing chain cassette let go we were able to rebuild the motor and found 6 bent exhaust valves, right hand cam was bent and was replaced with one out of a 98 Ford explore we honed the Cylinders, fitted new piston rings and bigend bearings, sealed, gaskets and water pump.The timing chain kit was from Cloyes I am a bit concerned about the Quality of this kit as the chains were loose in the links only time will tell.I have a 1994 Ford Explorer with a 4.0 V6. I purchased it used in 2010 with almost 200,000 miles on it. Had to rebuild all four power window motors do little tubes that go in there. Put a radiator in it two water pumps. Upper and lower hoses two batteries since then brakes. Power steering hoses. But I have yet to take the motor apart except for installing a new thermostat and I just crossed 400,000 miles to be precise 400337 miles. It goes through about 1 quart of oil a week but to me that is still cheaper than buying a used motor and putting it in or buying a rebuilt motor and putting it in I would like to see 500,000 miles then take a picture of my odometer and send it to Ford I love this engine
I know this is an old post but I now have 255K on my 2003 explorer with the 4.0L. My mechanic did say that the timing chain looked worn out when he replaced my valve cover gaskets.Oil changes every 3k and ford oil filter is about all you can do. Highest milage on stock chains I have seen is about 230k. Usually the main tensioner fails somewhere after 150k but some people ignore it and let the pieces get down to the oil pickup.
I have seen plenty of even 97-98s even make it to 200k on stock chains, they all were taken care of though.
the chain or the guides? the chain doesnt stretch a whole lot in my experience, replaced the original primary guides (the other chains guides are still OE) in summeer 21 at 310k no slack that i could tellI know this is an old post but I now have 255K on my 2003 explorer with the 4.0L. My mechanic did say that the timing chain looked worn out when he replaced my valve cover gaskets.
The more interesting part is that you have a 2003 in Pa and is still drivable without it being rusted to pieces. BTW- I live in Pa.I know this is an old post but I now have 255K on my 2003 explorer with the 4.0L. My mechanic did say that the timing chain looked worn out when he replaced my valve cover gaskets.
Well, mine has 176,500 on it and no rattle from the engine. Previous owner changed the oil! Semi synthetic for them, synthetic for me. Once a year for me as I don't do a lot of miles so far.I have had my v8 for close to 9 years now and never read much about that wonderful piece of art from Ford called 4.0 SOHC. Now, that I got also 07 with v6 now with 116k miles, I need to get educated.
Thanks
