lift and tires? true 4WD? | Page 2 | Ford Explorer Forums
what kind of lift would I need to fit 35's under my truck?
Something very BIG and expensive. Probably some sort of drop bracket lift (Superlift, Trailmaster) or Long arm kit (RCD, Dixon Bros) that'll get you 4-5" of lift so you can fit 33"s, with a 3" body lift on top of that, then you might get 35"s on there, probably still need some fender trimming, but each truck is different. If you go the drop bracket route, you could still torsion twist the front and shackle the back for a couple more inches. Either way, you're looking at $2000-3000.
Your best bet for 35's would be to Solid Axle Swap the front, and Spring Over Axle the rear. Again, very expensive ~$5000 depending on your fab skills and access to parts.
ok one more question, I swear its my last lol. Ok I was looking around to start buying parts, but what do I need to buy for the add-a-leaf thing? is it universal? could someone post a link to the one I need to get, and is there a writeup on how its done?
thank
