thanks man i also found a long travel kit for 1991-2001 ford explorer from dixon bros racing. but how much of a lift is the torsion bar twist and shackels give u
Usually people only go 2 inches or so of lift with the torsion twist, but that's because anymore makes the cv shafts wear increase. Since you have 2wd You could go more then that.
ill keep that in mind thanks. im just debating on if i should do the long travel which will give me 4 and half inches and it also replaces my torsion bar system but im definatly goin to go with the warrior leaf spring kit.
