Hoppy
- September 8, 2000
- Ontario, Canada
- 2000 XLS 4x4 SOHC
Hello all,
I have a 97 Explorer 4x4 and have an opportunity to pick up a trac lok differential for it from an 88 t-bird turbo coupe. I realize that there may be a chance that by installing the new differential in place of the limited slip differential it may throw the mesh off on the gears.I am not changing gears, I will be bolting the existing ring gear onto the new differential. I just want to know if anyone has done this before and if it is possible that it will change the mesh. I just want to know before I go ahead and change the differential so I can get a couple handfulls of shims for it before i do perform the swap.
Thanks guys,
Hoppy
Thanks guys,
Hoppy
