Lincoln Aviator 2004 | Ford Explorer Forums
bobby7lk69
BULLHEAD CITY
2004 Lincoln Aviator
My items are as follows - park assist - when vehicle is put into reverse there is one beep and then nothing. Took to a shop with hi end scanner and no go. Checked all fuses , wiring , replaced one sensor ( was not bad ) . When in reverse you can hear each and every rear sensor (4 of them ) , clicking as they should, which leads me to believe that the PAM is working as it should. any ideas?
Second is cruise control. When switch on steering wheel is actuated , nothing. Normal should be yellow indicator on dash. Also took to shop , no codes ( they said ). However if you are at speed and turn on switch , then set , green light turns on as though it is working correctly , but slowly loses speed. Checked all wiring , fuses , etc. , even replaced CC module . Nothing works so far. Thanks for your time , hopefully someone has idea. I have actually kicked around both might be related!
