strictly11
- March 1, 2016
- Connecticut
- 1999 Explorer Sport
Hey all, new to the Explorers.
I was chasing a bad tire. RF to be exact. While checking suspension and steering, I found considerable sidetoside movement in the steering. I could move the wheel sidetoside and the movement would go through the rack to the other wheel and up to the steering wheel. Tie rods are tight, inner and outer. Everything moved together, but it felt like it was too easy to move it as if there was air in the rack, or not enough fluid. It is a noisy pump, fluid level is good, I'm suspecting the pump is on it's way out?
Is it normal on the Explorers for this easy of movement?
