losing oil into thin air... | Ford Explorer Forums - Serious Explorations
FMExplorer
the original tramp
Fort Myers, FL
'99 Explorer EB
I go through about 1 quart of oil every 2500 miles or so. Granted, I change the oil every 3k, but I am not sure where this oil is going. Plugs are clean, no smoke of any kind from the exhaust. Any ideas? Oh yeah - nothing on the ground either<G>
Jon M
Jon McLeod
'93 XLT
K&N Drop-In
Modified Airbox
Kenwood Audio w/ 6-disc changer
31x10.50 Dunlop Mud Rovers
Rancho RS5000's
Next project: visit http://www.jonmcleod.com for more info!
Jon,
Your problem is probably a leaking intake manifold gasket. If you pull your #5 spark plug out and check it, I would say you would find a considerable amount of carbon build-up on it. This is generally where the intake gasket leaks and it is drawn into that cylinder. If you think about it, you may even notice that you have also had a slow coolant leak. That is another clue that goes along with it. You can check out this link and it will give you more detail. I know it says it is about pinging, but that is where the solution is found. Dead Link Removed
Good luck.
Ira
91 XLT 4x4
You're just jealous because the voices only talk to me.
Ira,
Thanks for the link. I will check out the plug tonight as they are real new. BTW - I am jealous, why won't the voices talk to me anymore???
Jon M
Jon McLeod
'93 XLT
K&N Drop-In
Modified Airbox
Rancho RS5000's
