jacksonh18
- April 19, 2014
- Kalispell, MT
- 00 4.0 OHV 4wd
the code at Autozone was P0174
I just finished putting new heads, pushrods, rocker arms, plugs, plug wires, Gibbs break in oil, thermostat, radiator fan in.
Occasionally the oil pressure gauge is going crazy and I just replaced the oil pressure gauge switch (sending unit). I am now installing a real oil pressure gauge.
I purchased some mass air flow meter cleaner and I'm about to clean that.
What order would you go thru checking these things? Is there a way to test a mass air flow meter? (it's over a hundred for that part)
