DasBaldDog
- December 17, 2010
- Greensburg, PA
- 1994 XLT 4.0
Figured out my orphan wire and faulty starter problem and ran to Autozone to pick up some random stuff.
While i was there, I borrowed their vacuum gauge and am getting a VERY steady 14 inches of hg. This is the same reading I was getting before I embarked on my long mission to replace all the intake gaskets. On said missions, I found a fairly deteriorated intake manifold gasket and figured that was it. Apparently not.
Like I said the vacuum is steady at 14 inches. Warm idle is about 700 rpm or so.
All the vacuum guides say late ignition, plugged exhaust. Definitely not the exhaust... New cat, new muffler. Shouldn't be the ignition, it's set by the computer and I should get a CEL if it retarded the timing, right?
I sprayed out the IAC with carb cleaner but have no idea if it's leaking. Sprayed the entire engine with carb cleaner, no leaks so far as I can tell.
What's next to check? Am going to go buy my own vacuum gauge after work today so I can more easily check at home.
