Solved - Lower intake manifold bolts | Ford Explorer Forums
Solved Lower intake manifold bolts
Prefix for threads that contain problems that have been resolved, and there is an answer within the thread.
Lee's Automotive
Git-R-Done
Location
United States
Alabama
99 Explorer XLT 4.0 SOHC
Hello I'm in need of lower intake manifold bolts for my 99 explorer 4.0 SOHC as I have a missing bolt
Salvage yard is prob your best bet, unless you can measure the thread and length, and have a great local hardware store (probably something industrial like Fastenal).
I do believe I have them
Ill send them to you but I think it would be way cheaper for me to just measure the bolt and give you the specs to buy one at the hardware store
You could buy all new bolts for just the shipping costs just sayen
Could you put 2 in a envelope and send them over?
Let's make sure everyone is on the same page.
When I posted Don had them, I was referring to a post were he had upper bolts. You needed the lower bolts, so I edited the post.
Just want to make sure everyone is talking about the correct bolts.
😥I should just go to bed 😂
Nope your fine bro I'm just trying to get this bolt because I'm leaning out on bank 2
I have them all upper and lower
If you can't find them at the hardware store pm me
But ill tell ya 30¢ is way cheaper than shipping
At least take the time to look before I spend way more money shipping
And I have no way for you to repay me
Not sure what you need but the 4.0 only has one intake the platic intake attaches to the heads, do you need head bolt? or the 10mm small intake bolts. If I were you I would go to a junk yard that will let you go out into their yard by your self find a explorer and remove the front intake bolts real simple. The yards by me don't mind if you take parts off an engine because if the engine is still in the truck its bad.
Yeah the 4.0 SOHC has a 2 piece intake so the lower intake bolt hole in the head is stripped so I'm gonna get a heilcoil to fix it
Issue Solved thanks to @donalds for sending the bolts thanks everyone
