Luk clutch kit | Ford Explorer Forums
Luk clutch kit
Siekyre
Location
Hillsboro, OR
Hillsboro, Oregon
96 5.0 XLT
We just installed a Luk Clutch kit, new flywheel, and a new slave cylinder. After bleeding (4 times now), the clutch is still really soft and the friction point is still just off the floor, less than 1/2 inch.. Any ideas as to why, or the next diagnostics step? Thanks
Did you get air in the master cylinder?
No, we made sure the fluid level in the reservoir stayed topped off.
Bad slave is possible if it's aftermarket. I've seen brand new ones just never be right.
I know i had problems until in inverted the master cylinder to completely bleed the system.
Thank you for the replies. :)
