MAF sensor wiring | Ford Explorer Forums - Serious Explorations
MAF sensor wiring
DaveWC
Independence, MO
1997 XLT control trac 4wd
I recently read through a book explaining hydrogen generation application for automobile use to increase mileage. The downside is that on the newer computer controlled fuel systems, some "adjustments" need to be made to signals to the ECM from certain sensors in order to gain mileage without hurting the engine. One particular is to adjust the signal from the mass air flow sensor. What I need is the wiring diagram/schematic for the MAF sensor on my 97 xlt 4.0 SOHC V6. Thanks for any help, DaveWC.:usa::D
Attached!
Red is positive (5v)
Blk/white is ground
Tan/LB is MAF sensor return
LB/R is MAF sensor input
Later-j
