Doug904
Sponsor
- March 30, 2001
- Jasper, Alabama
- 2005 Roush GT
huskyfan23 said:So aftermarket MAFs in general shouldn't be used? Pro-M is the same thing as Granatelli.
I know the views here and I've tried to kinda lean away from this info but in my own experiences along with my tuning knowledge I wouldn't recommend a Pro-M or any aftermarket mass air to my worst enemy.
One is because on a n/a engine, 4.0-5.0 in an Explorer, your not going to outflow it. Spend your hard erned money where it's best, in a good air intake system and cat-back exhaust. From there get a SCT product, chip or tuner, and you've done just about everything you can for your daily driver. Now for a racer or someone looking to get every last bit you may wanna get the headers but those too aren't something I would recommend as a first mod.
Whipple superchargers uses a SOHC 4.0 65mm stock mass air with the supercharger kits for the 3.0. Explorer Express uses the stock 65mm mass air meter with the BASE kit, anything over base and you'd need to go to an 80mm GT or some other Ford meter.
Two is the way the tuning has to be done to compenstate for any aftermarket meter, not a larger Ford meter. You have to adjust engine displacement and on calibrated meters for larger injectors hi and low slopes on the injectors to get it close. Then you have to dyno tune them from there to get it right. At best you end up with a good WOT readings and a marginal idle.
Three is the way they treated us at last years V6 Ford Challenge Race in Milan Michigan, I won't go into it unless requested but to put it quick they lied for free advertising. I completely lost respect for them when they did that.
Like I said it's just my views and for a stock Explorer their meters may work fine but in MY opinion I would rather someone stick with a Ford factory meter.
Thanks, Doug.
