- March 16, 2013
- Woodstock, GA
- 04 Ford Explorer 4.6l
I wanted to create a list of "how to's" by [MENTION=229411]makuloco2000[/MENTION]. He does some great videos on common repairs. He has a Youtube channel that you can subscribe to. If you watch his video's take a look at some of the ads so he gets credit for the work he's done.
Disclaimer: I have no affiliation with makuloco2000, other than I've subscribed to his Youtube channel.
Battery Draw Testing:
http://www.explorerforum.com/forums/showthread.php?t=399233
Bench Bleeding Brake Master Cylinder:
http://www.explorerforum.com/forums/showthread.php?t=398099
Blower Motor Only Works On High:
http://www.explorerforum.com/forums/showthread.php?t=409446
Checking and Adjust Trans Fluid Level 5R55S:
http://www.explorerforum.com/forums/showthread.php?t=396615
Cruise Control Inoperative Diagnose:
http://www.explorerforum.com/forums/showthread.php?p=3319443
Ford Power Steering Pump Teflon Seal Install:
http://www.explorerforum.com/forums/showthread.php?t=404166
Improved Front Hub and Bearing Replacement:
http://www.explorerforum.com/forums/showthread.php?t=402670
Load Testing Alternator On Vehicle:
http://www.explorerforum.com/forums/showthread.php?t=399270
Noisey (Noisy) humming noise front end (sic):
http://www.explorerforum.com/forums/showthread.php?t=393780
P2135 Throttle Position Sensor Replacement:
http://www.explorerforum.com/forums/showthread.php?t=402971
Resetting the PCM after Repairs are made:
http://www.explorerforum.com/forums/showthread.php?t=396533
Solenoid Pack Replacement 5R55S:
http://www.explorerforum.com/forums/showthread.php?t=396613
Trans Range Sensor Install No Special Tools Required:
http://www.explorerforum.com/forums/showthread.php?t=401665
2002-2005 Ford Explorer Rear Wheel Bearing Replacement:
http://www.explorerforum.com/forums/showthread.php?p=3356232
2002-2005 Instrument Cluster Removal Procedure:
http://www.explorerforum.com/forums/showthread.php?t=405633
2002-2010 Ford Explorer Temp Blend Actuator Removal:
http://www.youtube.com/watch?v=BERmZRDfqPw
4.6L & 5.4L Engines Alternator Replacement:
http://www.explorerforum.com/forums/showthread.php?t=402479
4.6L Power Steering Type Whine Noise:
http://www.explorerforum.com/forums/showthread.php?t=401147
5R55S Harsh Reverse & P0741 TCC Performance Valve Body Replacement:
http://www.explorerforum.com/forums/showthread.php?t=413221
Edit: 02-23-2016
2002-2005 Ford Explorer Door Ajar Light: Common Door Wiring (doors won't lock unlock from drivers side)
https://m.youtube.com/watch?v=egIGBzO065U
If I've missed any, let me know and I'll add them. Some of his solutions may be buried in the questions posted by others.
Edit: 02-23-2016
