Mass Air Flow housings | Page 3 | Ford Explorer Forums
On another note I did some "Free Mods" to my EX.
Here's what I did;
***Note, if you don't feel comfortable using hand tools or don't know exactly what you're doing, DON'T TRY THIS.
I was a machinist for 5 years in my earlier years so I have experience.
Went to Home depot and bought a 3" flap wheel 60 grit. (Uses the DIA side to grind and not the face) It looks like strips of sand paper glued in the middle. This fits perfectly into the stock MAF and throttle body with just a little force to get into bore.
MAF - I took the stock sensor out. (Note* Once my sensor is out of the housing there is a straight thru bore. In other words there's no plastic in the design to direct airflow. If yours is not like this you can't do this.)
Took the housing and ran the flap wheel in the bore very carefully with a cordless drill set to high RPM'S. I found the cordless drill to have the right RPM's to do the job. You don't want to run extremely high rpms doing this. The way to judge is how fast the heat is generated when "honing". Once I felt the plastic getting to an uncomfortable to the touch temp I stopped and let cool. Then proceeded. (KEEP THE DRILL MOVING IN THE BORE AT A CONSTANT SPEED to keep bore consistent thru out) I had an ID mic to see how much material I removed. I took around .060 from the ID (10-15 Minutes of sanding). But mostly removed a lot of the flat where the sensor mounts on the top of the bore and smoothed out the flashings. You can't remove to much because the sensor still needs to seal so be careful here. (Hone...Check...Hone....Check...Hone...Check) After done clean very well.
Throttle Body - Leave the "butterfly" in and closed. (Note* Do NOT hone the bore where the Butterfly is.) This is bad and the butterfly will not seal against the bore and your engine won't idle right). The trick here is to hone all the way up to where the butterfly is from the TB side pointing forwards when installed. This is why I say to leave the butterfly in and closed. Same principle. When you feel the metal getting to a "Uncomfortable to the touch temp" stop and let cool. Again, I took around .060 out of the bore up front. The bore will natural start to taper in towards the butterfly. This is okay. After done, I took the butterfly out and put it back together with the rod out of the TB, ground the ends of the screws and flattened out the rod on the tops and bottom. What I mean by this is if you're looking into the throttle body when the throttle is floored, you're looking at the end of the butterfly. The top of the rod that the butterfly is connected to is...the top...the bottom...the bottom. The idea here was to remove just a little so that more air could flow when floored.
BE CAREFUL with this step....
Then I took the butterfly out being sure to keep note where the end was you see when floored. The idea here was to grind bevels on the end where the air flows in but not to much where you change the DIA of the butterfly. Grind too much here and you're in trouble. It won't seal anymore and you're looking at idle problems. After done I cleaned very well and put throttle body back together. When putting back together you can make you're throttle easier to push by how many times you twist the load on the springs. I twisted 1 time only. I think stock was 2 to 3 twist. The throttle is much easier to push now. Your foot will like this on long trips. Just be sure the "Less tension" will properly seat the throttle body with your foot of the gas. Test and make sure you have enough tension on the springs. No one want's to have the throttle stick open.
As for the results of the mods. I noticed better throttle responce right of the bat. Not sure about mileage yet as I'm in the middle of figuring this out.
Not sure how are if I have access?
You can't upload pictures, but could link them from another website. It would look like this:
thanks brooklyn. Sorry there not clear.
That's basically what I did, I just bought those parts that someone else modified, as opposed to doing it myself and possibly messing up.
if you have a belt sander you can thin the butterfly and the knife endge it its alittle easier as long as you have access to a good bench belt sander.
aldive said:
They have been out of business for quite a while.
id read that too but what ever site I was at(and now cannot find) there ordering system allowed me to add one to the cart. I was under the impression they switched hands.
any pics of the c&L?
edit: never mind I see were my wires are getting crossed, the metering tube looks to be part of the 4.0sohc sensor. on my 5.0 the elements are open when the sensor is removed almost like a broken light bulb. not to say I still couldn;t provide enrichment elsewere.
I just checked my email and read about the bug bite thread, then went right to this email and read that. Man that was funny!
I think i have an extra tb here i might screw around with.
Has anyone tried any intake mods? I bet just given it a good cleaning could help those with a lot of miles.
au01st - I actually conceived this idea from you and spindleclone, so credit to you for posting the pics.
I don't think these gains are in my head. It's been done for a few days and I still notice the difference. I plan on getting dyno'd as soon as I get an Itake, exhaust, and SVT. (Yes, I'm going at this backwards) Partly because I want to feel the biggest mods last. That away I know the little ones worked.
At the trac meet in L'ville last week,A stone cold 01 trac with a ported TB (25 extra CFMs) made 7 RWHP extra (dyno proven)
I better make my self a little clearer.
When I asked if anyone had tried any Intake Mods, I meant the pc. the throttle body bolts too. I noticed a tube for the ....I've went blank and can't remember what you call it (Something valve). Anyways, there's a metal tube if you look in the hole after removing the TB. I wonder if this could be maybe "Bent" in a vise just a little? Not to much but just a little to help the air get by it? That, and that comb looking gasket. I think I read somewhere that the combs could be removed. Why are they there? I assumed to help break up the incoming air.
Okay, I remember the tube name. It's for the EGR Valve.
If the modified TB would produce results, I'm wondering if modifying this tube would do anything. For example; what if you were to shorten it a little? Maybe shorten it a lot? Then re-drill the holes that's currently in it. From my understand this is where the exhaust gases are coming back into the intake to somehow help the engine run cooler and prevent detenation? Doesn't make sence to me but oh well. Anyways, if you could remove a good portion of this tube wouldn't this help more CFM's just like the TB mod? Or, will this screw up the EGR system? Anyone?
I was a bit nervous but I did this EGR mod.
Took the intake off and used a tubing cutter to remove most of the EGR tube located, and blocking, the intake just after the TB. The EGR still functions normally. No CEL.
The reason the tube is so long in the first place is to discharge the exhaust gases evenly to all cylinders. But, because I learned that the EGR does not function at WOT, I went ahead and tried. I figured I'd rather not have a pc of pipe blocking the intake air like that and if something went wrong I could just get another tube. Also, I ported the mouth of the intake as well as a good cleaning.
Pics. Later (It's dark)
The results.
Positive;Feels to have more power, especially at WOT, and higher RPM's. A little more throttle response.
Negative;None that I can see or feel. But, with removing a portion of this tube now prevents the exhaust from being distributed evenly. Probably (In theory) most of the gases, when the EGR valve is open, is going to one side of the engine. I can't think of any ill effects this will cause. Only time will tell.
Summary; I like the performance I gained from this and don't think that there well be any problems. Also, I talked with a tech tuner guy and he felt I wouldn't have problems with an emissions test either. Ofcourse I want to be legal and abide by the laws.
By the way. My average gas milage with all these "free" mods is around 19.72
This is Highway and city together. I don't just drive on the highway and don't just drive in the city so there mixed. But, I'd guess that 75% was highway and 25% city. A few really fast starts are included cuss I felt the need for speed.
Post pics for sure, im really interested in this
Ported throttle body = what Jakee did or was it bought aftermarket?
It's not aftermarket. I'll post pics tomorrow of this mod that are clearer. Also, I did a little more so it's different than the first pic I posted of the TB. (I actually cut a full section off the non threaded side of the bar that holds the butterfly) No problems. Just take your time if you decide to do this.
Here's a pic of the TB mod. Notice the thickness of the bar that hold the butterfly. I removed more than half from stock.
Heres the Intake and EGR tube mod.
