timtimtimajim
- May 29, 2014
- Colorado Springs, CO
- 1993 Explorer Sport
Another project I need to start thinking about. Engine cooling. The entire cooling system on my Ex has been replaced (radiator, radiator hoses, water pump, fan clutch, fan blade, thermostat) as well as a good system flush. The A/C has also been removed. But even still on hot days the temp rises above half way on the gauge. Not to the point where it's dangerous, but it makes me really uncomfortable. And over long hills/mountain passes the temps rise so I have to crank the heat in order to maintain the temperature at halfway on the gauge.
There's two things that I want to do. First is an all aluminum three row radiator. Are they still being sold? Anyone have the link?
The second thing I've been thinking about is running one or two pusher type e-fans on the front of the radiator in order to supplement the mechanical fan. I would just want something that I can turn on and off manually with a switch. This would keep the system fairly simple and would allow me to have complete control over it. I think it would work because cranking the heat to help cooling is more or less like using an e-fan. But instead the e-fan would be on the radiator and would help maintain temps in traffic, slow off road crawling, and on long grades. I've seen systems like this before that have worked on other vehicles, so I don't see why it wouldn't work here. What do you guys think? Crazy idea? Should I go about it differently? Or would it work?
