MFT/Sync Trouble using Playlists | Ford Explorer Forums
Pas1963
Valrico, FL
11 Exp LTD - Gold Leaf
Anyone else having issues with playlists with the USB port. Tried both an MP3 player and a thumb drive. No issues with music via artist or album, the index sees the playlist but has no songs associated with them. I am using Media Monkey to index and load the music from the computer. Any suggestions would be appreciated.
Thanks in advance,
Paul
Works perfectly with my zune.
Maybe try using WMP to make the playlist?
Hey, a fellow Zune user!
I posted this somewhere else, but wanted to check again.
What size Zune do you have and how long does it take to index when you connect it?
If you use Zune Pass, or just buy music often, and the music you have on the Zune constantly changes, I'm under the impression it re-indexes each time you connect it. Have you found that to be the case, and does that mean you're waiting 20-30 minutes or longer each time you plug your Zune in and go for a ride?
My zune I leave in the explorer is a 30GB (I think...early zune). It probably took ten minutes to index. I don't use the pass or change music often. All my CDs are ripped, I use it as a backup for when I want to hear "my stuff".
Having replay on Sirius is really making me consider a subscription. I wish they had it on FM also.
This is making me miss my zune...
