timfretwell
- December 19, 2000
- Roanoke, VA
- 94 XLT
I was inspecting the stock air intake on my 94XLT the other day, and I did two things that I believe are improvements that only take a few minutes. If you follow the tube from the air box to the grill, you will see that the tube screws to the inside of the grill. On the "front" side of the grill is a square black cover that covers the intake hole. The cover has a slit in the bottom and side. This seems to really restrick air flow. I laid on the ground and with a long flat blade screw driver, I was able to pry the cover off. Next, on the front of the grill beside the head light there is a rubber flap attached to a plastic bracket. This flap simply pulls off. This allows air to flow directly from the grill straight into the intake tube. The plastic bracket(without the flap) actually acts like a fin to divert air to the intake.
I can't tell any difference in highway performance, but I do think the city performance is a little better. I am currently checking to see if it will help my gas mileage any. I'll keep you posted...
