maidez
- December 11, 2011
- 2002 XLT
Today I spent a very frustrating day trying to compress Moog coil springs on my new KYB struts. I had taken out one of O'Reilly Auto's MacPherson strut spring compressor, and went through several failed attempts of trying to 'grab' the right number of coils with the compressor so that I could re-attach the coil seat, and subsequently extricate the spring compressor. Either the compressed spring was too long to fasten the seat, or there was insufficient clearance to remove the jaws of the compressor from between the coils. I had done my rears several months ago, so sorta, kinda thought I knew what I was doing.
When I finally gave up, and decided I would just bring the struts and springs to a tire/suspension shop and let them assemble everything, I decided to check the old spring against the new. I usually compare old and new parts first thing, but skipped this step because I apparently haven't suffered enough in my recent past. The Moog coil springs I purchased (Moog part 81132) are roughly the same length, but there are two more spring 'winds' over this length. These extra turns result in a much tighter spacing which is probably why I had so much more trouble with the fronts. I checked on Rock Auto's and Moog's website to confirm that part #81132 is correct for my 2002 V6 Explorer XLT front struts.
Now I'm not sure if I should proceed with my plan of having a suspension shop compress these springs. Has anyone seen Moog springs that appear to be significantly different than the OEM ones in this manner? Any idea if I would experience noticeable suspension/ride problems if I used these ones? I suspect that if Moog did this on purpose, it would be to firm up the ride; I'm OK with that, but just want to make sure this is an intentional change before I reassemble everything.
