Moonroof Help | Ford Explorer Forums
Moonroof Help
Brian C.
2013 Ford Explorer XLT
I have a 2013 Explorer XLT, got in today and it appeared to have some light water on the sunshade. I opened the shade normally for just the front moonroof portion to inspect. I then opened the shade all the way back to the rear moonroof and then closed but it will not close over the front panel. Also when opening the moonroof for Tilt or Slide, it is not closing to its proper closed seated/sealed position automatically. I am having to eyeball it to ensure it is even with the back glass assuming it is sealed. Any ideas?
Also, based on the water I am assuming the drain lines maybe clogged which seem easy enough to do but I only see a hole on the passenger side. Is that the case on this model?
