Definitely. I checked the drain hoses and they didn't seem blocked or anything. Having the right tools there at the time would have helped a lot. hahaWhile you had the headliner down that was the best time to air nozzel those drains out. You can also fish a peice of wire down the drain from the top if you don't have access to air compressor. Try dumping water down the drain with a cup with the roof open to make sure it drains.
I have tried jumping the sunroof, Jumping the battery, shutting it manually, spraying everything. I'm about to put a bag around it again until I can figure it out... Oh and ty muchhave you lubricated the rail? is the motor for shade and roof different? how are the connections? different fuses? can you try to give it a little bit ot help, mahbe theres some friction to overcome
in the time being, you could try using some tape to try to tape it shut if it doesnt budge
by the way, welcome to EF!!!
It was leaking at first with poodles in my passenger side. The shade comes up half way and that's it. Dropping the head liner? I pulled out the monitor card to look at it and tried to shut it manually but still nothing. I'm changing the fuse tomorrow which I saw was fuse 8 in the engine department one.could be a fried motor or a bad connection. Where and how exactly did you try "jumping" the moon roof? It sounds like dropping the head liner is in your future.
Welcome to the Forum.It was leaking at first with poodles in my passenger side. The shade comes up half way and that's it. Dropping the head liner? I pulled out the monitor card to look at it and tried to shut it manually but still nothing. I'm changing the fuse tomorrow which I saw was fuse 8 in the engine department one.
The replies generally said, no, there is no way, and there are two motors.The moonroof on my 2011 Explorer is now stuck open in the tilt position. Both the shade and window won't close, presumably from the water leaking into the truck and the overhead center console where the control buttons are. Is there a manual way to close the glass?
Here is a thread that had a similar issue:
Is there a way to manually close the moonroof (tilt)
The moonroof on my 2011 Explorer is now stuck open in the tilt position. Both the shade and window won't close, presumably from the water leaking into the truck and the overhead center console where the control buttons are. Is there a manual way to close the glass?www.explorerforum.com
The final reply, despite nobody saying they had their issue truly solved, was this:
Your mileage may vary.. I am sorry I couldn't be more helpful. That being said, you could put a tarp over it while it rains. I mean of course, right. That is not ideal though.. I've been there before in a few cars I've had, it's really frustrating. Please definitely check the fuse and let us know if anything changes and any updates!
