Flandry
- August 27, 2007
- Birmingham, AL
- 1993 Sport
A little while back, Brooklyn Bay posted an email he received from a friend on increasing fuel economy at the pump on Aldive's Quest thread. I thought I'd give this one a try:
It's taken me several tanks to confirm the results, but this does seem to work. Near as I can tell, pumping gas at the slowest setting gave me an apparent average mpg increase of around 0.6%. My previous best mileage was 20.13 mpg. With no other changes, but the way I pump gas, I've achieved a new best of 20.32 mpg. Obviously this is a very small gain, and not a measure of actual increased fuel efficiency in my truck (I just got more of the gas I paid for). But it's free and easy and looks like it allows me to keep a little of the money I'd otherwise be giving to Big Oil.
4. If you look at the trigger, you'll see that it has three delivery settings: slow, medium, and high. When you're filling up, do not squeeze the trigger of the nozzle to the high setting. You should be pumping at the slow setting, thereby minimizing vapors created while you are pumping. Hoses at the pump are corrugated. The corrugations act as a return path for vapor recovery from gas that already has been metered. If you are pumping at the high setting, the agitated gasoline contains more vapor which is being sucked back into the underground tank, so you're getting less gas for your money.
