more probs with my ohv 4.0 | Ford Explorer Forums
powa_ranga
grass valley, CA
'00 ranger xlt4x4
Ok, I pulled the code for my truck and bank#1 was lean, and the cats are fine. It was running lean on 1 cylinder and i replaced the worst 2 injectors on that side and put everything back together. then when i started it, it ran horribly on what i'm assuming was 4 cylinders. so i pulled it back apart and put the original injectors back in and it still ran the same way. i have no clue what could be the prob now cause it ran ok on the original injectors. so now i'm stuck with this damn thing and it has spark and air but i'm assuming no fuel, so whoever has any suggestion i am in desperate need of them, i'm supposed to drive this thing to so-cal this week
My guess is you may have caused some damage to the injector wiring or something else when you installed the new injectors.
bingo, your right, fixed it after pullin it apart a 3rd time
