crunchie_frog
- June 19, 2010
- Johnson City, TN
- Multiple 99-00 5.0 AWD
I have 99 awd 5.0 Mountaineer with the center console computer display. I used the mpg calculator on several tanks and it matched the mpg I calculated manually at refills so I was confident it was accurate. I was interested in how the mpg varied at different speeds so I used the mpg calculator on the computer to do this. I travel ~10 miles every morning during the week via a relatively uncrowded section of interstate. I used the cruise control to set different speeds and measured the mpg for the exact same section of interstate. I never touched the brakes during the tests and weather conditions were similar (dry, cool) for all tests. I checked the mpg at each speed 3 different times to get the average mpg at those speeds. The mpgs at each individual speed never varied by more than +/-0.1 mpg. The results are below:
55 mph - 23.7 mpg
60 mph - 22.5 mpg
65 mph - 21.7 mpg
70 mph - 19.7 mpg
I thought some folks might be interested in how they might could expect their mpg to vary at different highway speeds. You can see there is quite a bit of difference between 55 mph and 70 mph, 4 mpg.
Also, these tests were done with 5W-20 oil, and I can say that my last oil change I used 5W-30 oil and I lost ~ 0.5mpg when I retested at some of the speeds. I am pretty sure this is why Ford changed their oil specs years ago to 5W-20 for many of their vehicles, along with the fact the lubrication is the same or better.
I am curious if anyone else has done any similar mpg testing using their center console computer and if you have could you share your results. I would be interested in how the mpg varied at speeds less than 55 mph. I was not comfortable with speeds less than 55 mph on the interstate as there was some traffic. At some speed, the mpg will start to go back down, I think probably around 45-50 mph or so.
55 mph - 23.7 mpg
60 mph - 22.5 mpg
65 mph - 21.7 mpg
70 mph - 19.7 mpg
