gottraction?
- April 23, 2011
- Atlanta GA
- 1998 Ford Explorer Sport
Ok i have spent the last 2 days reading about this switch but no one that i could find had the same exact problem that i do. i have an 1998 Ford explorer sport.(automatic) It has the bottom console with nothing in it. it does have the clock and degrees up top. the low beams are not working at all. you have to pull the multifunction switch back to get the high beams. I have replaced this cluster about 10 times with other ones from the junkyard. when i did about 8 of them would make the low beams finally work but the wipers would run constantly. Regardless if i tried to cut them off or not. if i adjusted the wiper speed it would start running the window cleaner. i have heard the buzz from the left turn signal in most of those switches as well. ive replaced the relay. still no go. I don't see any wires pinched on the steering column. Is it possible that all of those switches i got from the junkyard bad? the only that (sort of) worked was one that would let the low beams cut on. but i could only use the wipers when the headlights where set on bright! The truck has no aftermarket wiring that i know off. I don't even think a brand new multifunction switch would fix this now!!!!what can i do so i can start driving this thing at night?? Thanks guys!
