wipers mfs problem
I have read all 8 pages of this thread.
I have a 97 Explorer V6 4WD 4D. I have the occasional buzzing from the MFS. But that isn't the real problem. I can reliably turn the wipers on at high speed, only. The intermittent speeds and slow speed are very hit and miss. When I move the wiper switch from high speed to slow, intermittent or off, if the slower speed does not activate, the wipers stop where they are without returning to the home position. The washer worked intermittently as well. All other functions of the MFS were normal (hazards, turn signals, high beam).
So, I bought a junkyard MFS and had the same result. I took the junkyard MFS apart, cleaned it and put it back together. I sprayed electrical contact cleaner in the stalk where the end cap meets the stalk. I now have the same trouble except that the washer pump works reliably but the wiper motor does not activate. I cleaned the contacts on the wiper motor connector and swapped the wiper motor relay (located in the engine compartment fuse box between the master cylinder and the drivers side fender) with another one in the engine bay with no change in behavior.
When I turn the wiper switch one click to intermittent speed, I can feel the relay *click* once but nothing happens (the wipers don't move). When I turn it step by step it does not click again until I get to the 9th position (high speed) and the wipers begin to function.
When on the rare occasion that the wipers operate at the slower speed I can feel the relay *click* each time the wipers are activated.
It seems to me that there is either:
a) some electrical component between the wiper switch and the relay that interprets the switch setting and operates the relay accordingly that is not functioning properly, or
b) the wiper motor is not functioning properly
Any ideas are appreciated as is any direction to a diagram that illustrates the components of the wiper system.
