My 1998 SOHC 4.0 Won’t Start either | Ford Explorer Forums
bradford98X
Austin, TX
Explorer 98 XLT
My x wont start for nothing. Its got a full tank of gas the battery and starter are working but it just turns when i try to crank it. The theft light flashes rapidly when its in the on position. Can some one help also AAA came out to try and help me the guy tried to reporgram the keys but still didnt work and the computer said there were no defaults.
When you turn the key to the ON position, do you hear the fuel pump run for a second or two? If not, it could be the fuel pump relay, inertia switch, or the fuel pump itself.
If the theft light is flashing rapidly then it is the anti-theft system shutting down the fuel and ignition systems. This occurs when the computer does not receive the correct signal from the transponder key (your key has a chip that sends out a signal that the key cylinder pick up via an antenna in the cylinder.) when the computer does receive a good single the theft light will light up and stay lit till the engine starts.
I installed a remote starter in my x (98 sport shoc) last fall and ran I into this same problem. The starter would crank but no start, and the theft would blink rapidly. this was because there was no key in the cylinder. To get the starter to work I hade to buy a small unit that held a spare key. The unit then would pick up the key signal and send it to the key-cylinder via a small wire, that I hade to wrap around the key cylinder, when the key-unit got power from the starter-unit.
So you problem could exist in your key, key cylinder, or worst case something in you computer. I don’t know a way of figuring out witch one it may be, but may be this will narrow you search.
I would start with a new key-cylinder….
