98liftedxlt
- August 4, 2010
- Valdese, NC
- 96 EXPLORER XLT 4WD
No problem asking questions, You don't have auto hubs you have what is called a vacuum disconnect axle, so when that when not in 4wd the passenger since disconnects part of the axle, the wheel hubs are a direct link to the axle so there is no fault there unless the CV joint breaks. And you can put a manual case in but then with that axle setup you will have to put a toggle switch in your truck to control it or swap in a live passenger side axle from a 97+ex or 96 5.0 explorer or direct link it yourself or do what I did and just unplug the controller wire that goes to the axle under the hood then the axle is always "live" and normally don't have to worry about it because it's always connected.
Thanks for the info Glen4x4. That clears up a lot.
