my cruze dont work any ideas??? | Ford Explorer Forums
bigorange440
ABBOTSFORD B.C
94 EXPLORER LIMITED
i went to use the cruze the other day and nuttin .its on my 94 explorer limited..any ideas or quick checks......thanks
Check for vacuum leaks.
1st things I would check would be the fuse and, as hartman said, make sure the cruise is getting good vacuum.
You might also want to check the brake switch located under the brake pedal. It's cheap and easy to replace.
