for some reason when i put my truck in reverse the reverse lights do not work, and i have no clue why i tested the bulbs off of the battery and both bulbs are good does anybody have any idea why they are not turning on?
most likely cause would be your neutral safety switch (digital transmission range sensor) at least thats what it was when i noticed my reverse lights werent working. where it is will depend on the transmission you have. if you have the 5r55e transmission it will be on the left hand side of the transmission. autozone has them fairly cheap.
the wire to check is black with a purple stripe. if you can run power to that wire and they come on then its definitely your neutral safety switch did you check all the fuses?
