- November 6, 2000
- 2018 EX Sport Concept
I say from the pics, while the rust IS a problem, you can use your angle grinder (and a hacksaw, one of those keyhole/blade holder type mini hacksaws works FANTASTIC for cutting into the rocker to get rust off where a big hacksaw can't go) to grind away the problem area, just use a wire brush on a drill (or a stiff round wire brush on the angle grinder for external rust, that really gets it down to bare metal, but don't use it on anything else, it will catch and kick back bad). Once it's all cut out, use some sheet metal (16-18 ga. steel from Lowe's / Home Depot is fine) to form the replacement panel, and JB Weld on. Once it cures, I'd prep with acetone/alcohol, then hit it with a can of the Rust Control Spray Enamel (and I would also suggest spraying INSIDE the rocker with it too, especially the back wall inside where the rust is bad, but hopefully you can brush it down to metal or at least get the scale off. There are also plastic caps on the inside of the rocker, facing the undercarriage so you can actually spray the paint inside the repaired part the rocker once it's sealed so it doesn't rust from the inside out) and then some spray-on bedliner as the finishing touch.
I might also mention you should try to seal up the rest of the rocker holes from the plastic side skirt mounts, preferably with JB Weld as well, maybe using some tiny pieces of scrap metal to give the JB Weld something to bond to in the hole. This along with the spray liner on the entire rocker should seal it up and prevent further rusting.
Save the rubberized undercoating for the fenderwells. It's too soft for exterior use on the rockers, and on warm days it'll be sticky and gooey and it'll be gross when your leg touches it or it scrapes off on something. This isn't a perfect fix, but it will seal up the hole and if you do a careful enough job, will last as long as the JB Weld holds.
As for the exhaust, maybe can the Dynomax unless you want to invest in it for that $220. Maybe ask the muffer guy how much to cut the stock pipe and clamp in a cheap muffler. If it's still a lot, those Thrush Turbos at Advance Auto parts are cheeeeeeeap after the 40% online coupons:
http://shop.advanceautoparts.com/we...uffler-Thrush_5291461-P_N3333C_P|GRP2023P____
Part # 17713, in stock at most Advance Store for local pickup.
$27.99 - 40% off = $16.80
$16.80 for a new performance muffler. And it'll be louder than the Dynomax since it's shorter. But you'd need a new pipe. For that I'd suggest the Walker Intermediate pipe:
http://shop.advanceautoparts.com/1/1/543156-intermediate-pipe-by-walker-part-43470.html
Part #43470, $14.99 (strangely less expensive than the shorter 2 door pipe)
Of course, if your pipe between the cat and muffler is in good shape and already 12-15 inches long, the Walker pipe might not add much length. You could always buy a standard length of pipe at the store and clamp it, or just have the exhaust shop weld in the Thrush muffler for you, though some shops charge a ton just for one or two welds. Having them cut a pipe and clamp it for you might be way cheaper. Just don't forget to somehow have the hanger still attached to the new pipe/muffler.
