my explo pulls to the right side | Ford Explorer Forums
ARTURPOLAND
POZNAN, POLAND
'97 HIGHCLASS
hi, My explo pulls to the right side (slightly). I have changed balljoints upper and lower, have allignment done. Bu t id doesn't help. Is this something wrong with the schock absorbers or maybe the bearings ????
If it still pulls to the right, it isn't aligned properly
Have them re-align, and print an alingment spec sheet, scan and post it here.
If you have trouble posting, pm me and I'll give you my e-mail
just another thought mnake sure the tire pressure is the same on both sides(i have a slow leak in 1 tire and it pulls real bad to the right when it is low when they are both at 35ish then it is great).
jtsmith is on the right track. A print out would be wonderful :thumbsup:
I recently had a front sway bar end link break and caused a similar issue; take a look at yours.
Good luck .......
