i have the 4.0 but do u know how to replace the oil pan gasket i dont know if its the same as the v8
You know how it goes. You start searching for one thing and end up ten pages from where you started, not even remembering what it was you were after to start with (well, till you really think about it anyway or hit the back button a few times) and find a gem. Your zip tie throttle cable mod was mine. I just bought my 2001 X Sport last week and thought it had pretty good power for a 4.0. Out of curiousity, wedged myself under the dash and what do you know. Enough slack for 3 zip ties, with a little space to spare. What a difference a few zips make. Thanks!
nice videos.
I'm curious, did doing the throttle cable mod cause your brakes to be extremely strong at first? For me after doing it, I went to slow down at end of my street and my brakes went on fully like as if I slammed them down. They have gone back to normal since but I'm wondering if this happend to anyone else? It's almost like it tightened both, or did I tighten both... Now that I think about it, I should check into that...
jlsparky7 said:Thanks man. Plenty more to come. Just need some more cash, dont we all.
Any advice on how to repair the drivers side electric window? I think the switch has gone out. The other three windows still work and I don't hear the motor try to run when I activate the switch. My plan was to pull the door panel and swap wires from a working window to isolate the switch. I don't want to break anything on the door panel. TIPS for disassembly are welcomed.
I have you beat by 164,000 miles J...
THANK YOU! i can't tell you how helpful all your videos are! You just answered about 53 questions i had about my new explorer. Thanks again!!
sparky, how about a video on finding the pcv valve.
Edwin
Nice videos, especially for newbees like me. Thanks, jlsparky7!
btcman said:My son has a 2001 Ford Explorer Sport that needs the body mount bushings replaced - foam urethane is gone or almost gone in all of the 3 sets of bushings on the side. We already replaced the rears with Ford bushings and the front bushings are rubber and look fine. To remove the old side bushings, the carpet has to be removed or at least pulled back far enough to get to the top of the bushings to unscrew the bolts from the bushings, plus the seats have to be removed or moved around. A video showing how to at least get to the top of the bushings would be helpful, but one showing the entire process of removing and replacing the bushings with Daystar bushings would be very helpful. I have looked and looked and have not found any videos on the Internet showing the process.
Since this is a big problem for 2001 Sport and Sport Trac owners and Ford does not feel obligated to help with the repair costs or even give us any TSB bulletins with repair procedures, we are left to fend for ourselves. Either mechanics or body shops in my area (Atlanta) have never done the repairs before or if they have, like 4 Wheel Parts, they want to charge $500-$600 labor for the repairs. Others who have not done the repair cannot tell you how many hours it may take and you know how the labor cost could soar.
