- August 14, 2004
- Denver,NC
- 1997 F150 XLT 4x4
You have mail.
The clicking is most likely the "One-touch down" relay. You may have a bad motor. If you remove the door panel and access the motor plug you can disconnect it and use a pair of jumper wires to swap the connection. Then if it rolls down your motor is good.
You'll have 3 fuses that feed the radio. Has the cruise recall been done on your Trac? If not then immediately disconnect the switch on the master cylinder and have it done.
Steve,
How can I tell if the Cruise Control recall has been performed on my 01 ST?
As always, thanks for the excellent information!
Do you have the stereo wiring diagram? I'm installing a new double din and want to know what the 2 extra harnesses are for and if I need to splice them into the new harness. Thanks!
