My photos/schematics/diagrams still available. | Ford Explorer - Ford Ranger Forums - Serious Explorations
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
EDIT: INFO NO LONGER AVAILABLE. Due to a PC harddrive failure and expiration of my access to Fords Tech Resources I cannot supply the info as before.
To avoid any complications from all the photos/schematics/diagrams I have posted here over time as related to this copyright issue I have removed them. If you need any that pertain to a problem you're having feel free to contact me and I'll send them to you personally. All of my personal content is still there. I did this as a CYA for EF and myself, less complications for everyone!
vjmetallo
rochester,ny
'03 sport trac
autolamp/auto dim mirror install
steve,i was wondering if you have wiring diagram to install an autolamp mirror on an '03 st-xlt 4wd,i purchased the mirror and overhead console together ,the console is done,but i was sent a diagram for a ranger,there seem to be some differences in the wiring for all the relays and headlight switch.thanks for any info,v.j.metallo
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
You have mail.
Myphony69mustang
South Jersey
Hey, I was curious if you have a how to install front shocks diagram and a Sway bar Endlinks Diagram. Thanks =D
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
THIS is better than the factory manual instructions for shock replacements.
The sway bar replacement HERE shows the end link replacements also.
rokr1292
richardsville va
'01 Explorer Sport Trac
Would it be possible to make a list of the diagrams you have and post the list here? Or is that too close to actually Posting them?
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
Lets just say, you need it/I have it for any Ford for at least 10 years back. ;)
Photos are mostly of my Sport Trac repairs.
pcampbell44
I was wondering if you have a quick an dirty wiring diagram for the lighting system on a 2005 Sport Trac. I am trying to add the wiring for a trailer, and have not had time to hunt and peck the wires for the proper arrangement. If you have a diag., would save me a ton of time! Thank you in advance, either way. :)
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
I was wondering if you have a quick an dirty wiring diagram for the lighting system on a 2005 Sport Trac. If you have a diag., would save me a ton of time! Thank you in advance, either way. :)
You have mail.:D
mennitti
Punxsutawney, PA
2003 Sport Trac XLT
I do not have permission to post in the How To forum. Here is my article from Car Audio & Electronics Magazine about How To install a remote car starter. The vehicle demonstrated on is a 2008 F-150. The only caveat is if your Ford has the GEM wake-up module. If so, this becomes difficult since you have to go through the molex plug in the door jamb and connect to the module inside the driver's door. Here is the link:
http://caraudiomag.com/articles/beginners-tips-remote-start-install
wvsportrac
Ohio
2005 Sport Trac
Would you happen to have how to install front and rear shocks for a 2005??
Thanks...:thumbsup:
MidnightRebel07
Pittsburgh, Pa.
2003 Explorer Sport Trac
WVST, where you from in OH/ WV. If you wanna take a drive to Pittsburgh I can help you change them out.
oij040173
Paramaribo
2004 Sport Trac XLT
My ST (2004 4.0L 4wd xlt) is stalling and giving code PO193.
What are the trouble shooting step?
Thanks in advance
RiccoFX
Brandon, Manitoba
2007 SportTrac Limited V8
I need the overhead console wiring diagram/pinout out of a 1998 explorer!
NVM, I found it from the Overhead page link.... :p
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
Thanks in advance
Fuel pressure should be 60-65 psi, have it checked. Make sure your vacuum lines are not broken and/or disconnected from the sensor which is located on the fuel rail, left side of the motor..
Sensor
P0193 - Fuel Rail Pressure (FRP) Sensor Circuit High Input
Possible causes:
FRP signal shorted to VREF or VPWR.
FRP signal open (gasoline only)
Damaged FRP sensor.
Damaged PCM.
Sending you the diagnostics.
Bfloexplorer
Buffalo
2004 explorer 4.0
p0193 - directions for troubleshooting
hello,
I have the same exact error code, but I have a 2004 explorer xlt 4.0? Can you please send me the trouble shooting for this?
Thanks,
Rhode Island, in the rust belt :(
Would you by any chance have a wiring diagram for the factory stereo in a 2003 sport trac?
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
But of course. Is it the standard unit or the Pioneer? I'll send it to you in a bit.:D:D
Standard double DIN unit, thanks!
