My tach isn't working | Ford Explorer Forums
tweakedlogic
memphis, tn
'92 XLT
It's nearly stuck at 3400 RPM. I say nearly because it will move up when I rev the motor. is there a fix, or does it need to be replaced?
thanks
bumpity
Same exact problem here... any ideas?
It's weird because it will go down to zero when the key is off. I have no idea.
Same here.. goes to zero when shut off.. i did use a multi meter and checked the tach test port under the hood, the signal to the tech at that point is working correcly IE: correct read out, so my guess is the tach is faulty, gonna grab a used junk yard cluster and see what happens, will let you know
bump
you gurus should know this.
Replaced cluster.. tach works fine for me..
all righty. thanks
