- October 12, 1999
- Pennsylvania
- 2024 F-150 Tremor
Well, today I was going to install my shocks. Unfortunately, in the right front wheel well, I noticed that I threw up oil or an oil substance when driving. I checked and it was all over in it, on the frame, on the shock, everything. I immediately popped the hood to see if I could see an oil leak or any other fluid leak.
I discovered the coolant reservoir (in front of the washer fluid) was completely empty. I never remembered it being totally empty, but I figured that was the case. I filled the coolant up front and revved the engine for a good 5 minutes. No problems, checked the coolant, totally filled, although I didn't add any to the resrvoir.
However, under and a little in front of the coolant reservoir, there was a hose that seemed to be disconnected. It was COVERED in this oily substance. It seemed to be capped off, or had some sort of valve on the top. Does anyone know what this belongs to? Could this be the problem?
I want to drive the Expy to the dealer for service, but if this is a coolant hose or similar, I know that could be potentially fatal to the engine. (Although a nice new engine to replace my 85000 Mile OHV wouldn't hurt, haha). Anyways, any help is appreciated.
