Phantom
- May 9, 1999
- Memphis, TN
- 07 Exp ST / 15 Exp Ltd
So the compressor locked up and spewed oil everywhere. I have the new compressor but have a few questions:
1. The instructions refer to measuring the amount of oil in the old compressor and removing a determined amount of oil from the new compressor. It also says to add 2 ounces if replacing the accumulator/dryer, which I am. Long story short, I cannot accurately measure the oil out of the old one as it is long gone. Am I good to run with the 7 ounces loaded in the compressor? Should I try and blow any residual oil out of the lines and condenser?
2. The 2 lines that go into the compressor are welded to a plate that bolts to the compressor. Below one of the line to the rear is what looks like a large nipple. It is hexed at the end, which looks like you can put a wrench on it, and it has a hole in the end that looks to have black plastic inside? What is this and does it need to be replaced for any reason? I have a picture but don't have it hosted anywhere.
Thanks for the help!
