Need A Little Help | Ford Explorer Forums
Need A Little Help
HIX
Denver, Colorado
94 Mazda 4.0 4x4 SuperCab
Ok, when I make a hard right hand turn in reverse my dropped pitman arm hits the dropped sway bar. How the heck do I fix that?
uh
well..you can either drop/raise the sway bar some more to clear it, or get double shock hoops for the front and lose the sway bar entirely.
you know what? It cant be hitting the sway bar in a right hand turn. The pittman ar is turned the other way!
I am getting it aligned tomorrow. Maybe that will fix it.
HIX, off the subject in this post. Did you ever see my post in your thred " CHANGE OF PLANS"? I found out that '98 Ranger front fenders are the exact same as yours. That way you can get the fiberglass for them. Do it man.
Looks like I will add it to my list...
1. New turbo for the MX-6
2. Extended shackles to raise the rear of the B4K
3. Rims
4. Fenders
