Need help.. Can some one please tell me if I can change a two piece upper control arm to a single | Ford Explorer Forums
Can a 2 piece control arm be changed to a single.. Please help.. Thank you
  • Help
    Votes: 0 0.0%
  • Help
    Votes: 0 0.0%
  • Total voters
Mr.Me.
Grand junction colorado
2001 ford explorer sport
Help can a 2 piece control arm be replaced with a single
Yes, it can however you will loose a certain amount of "caster" adjustment. Be sure to buy a set of camber adjusting shims for each side to help make up for it and achieve a good alignment. The stock camber plates do not allow enough movement.
Awesome thank you very much
