Need help installing fogs | Ford Explorer Forums
xj220
Seattle
00 XLT V8
My PIAA 520s just came in the mail and I'm looking over the instructions. It says to "find a power source to connect the switch power wire to." What do you guys recommend I use as the power source? Also, where's the best way to route the wires through the firewall? Thanks for any help.
Inside the cab, you can pull the plastic in front of the cup holders out and splice into the aux cigarette plug wires. I used that for a couple lighted switches. Also you can just grab power from the fuse panel if you don't want to pull the plastic stuff. Just find a useless fuse and secure a wire in there.
As for running wires, I ran my wires for my KC's and my Visor lights thru the door jam and down that slot between the hood and fender. If you push the wires down with a screwdriver you can get them to click behind the peice of plastic that runs under the windsheild.
Then just pull that plastic off right by the parking brake and run the wires behind that. Works like a champ
