Need Help Removing The Crank! | Ford Explorer Forums - Serious Explorations
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
1975 Ford Bronco 4x4
From my Briggs & Stratton... :D
Somebody threw a rod in my riding mower. So I got a new rod, but I need to get the crank turned because it got a little roughed up.
Here are some pics. How do I get it out? Those four little screws held the screen on and I can't get to those two 1/2" bolts underneath because The pull start mechanism is in the way.
How do I get the crank out??
Have you checked to see if it is pressed on. Might have to use a puller.
The recoil assy. is threaded.
Use a rubber mallet to spin it reverse of crank rotation.
