splodo49
Ejection seat man..
- June 17, 2003
- Tooele,Utah
- 94 XLT,75 FJ, 05 Cummins
I just installed a tranny temp sensor and gauge on my 94.I put the sensor in a port on the drivers side of the tranny.And wired everything else up once i turned the key on to check it the temp was allready showing 190 degrees (the truck hasnt even started yet)so i checked all the wires and even tried a couple of different grounds and its all the same.So i figured that i would drive it around to see if it would change and it did change it went up to 280 and stayed thier (and if my tranny was at 280 you and i know that it would be burned up :fire: ).so im looking for some help from you guys and gals thanks .
