WannaXP8
- September 13, 2001
- St. Louis MO
- 1998 Explorer
Im gunna use the switch that comes with the kit, and the relay, but I wanna be able to turn the lights on at any point, with the car on or off, with the lights on or off..but in the instructions they say you gotta run a wire off the high beam wire, and I dont see why you have to do that?? Then its got another wire running from your battery to the relay? Does the wire that you connect to your high beam mean that you can only use them when the high beams are on?? OR could I just run that wire thats suppost to go to the high beam wire, to the fuse pannel?? Help me please..
