2001ExpSport
- July 23, 2000
- Chicago, Il
- 2001 Sport
I bought a set of Hella 500's and they won't work. I have them wired to my fog lamp switch, but I don't have the fog lamps anymore so I want to use that switch for the 500's. When I connect the power(trigger)wire from the relay to the power wire of the fog lamp switch I can hear the relay click, but the lights don't turn on. Both lights are grounded and the relay is grounded. I know the ground is good because my lumalite is on that and if the ground was bad then the relay would not flip over anyway. I followed the instructions, but they are a bit unclear. The bulbs are good so now what? the instructionx saw to mount the trigger wire to the high beams....might that be the problem? I also checked the power line fuse and it is good.
HELP!
HELP!
