Need help with my explorer | Ford Explorer Forums
b-gangl
Somerset, Wisconsin
1996 ford explorer
Okay were to start,
My 96 explorer ran great for a long time. I let it sit for about a month and went to start it started right up. Let it run for about 30 min and came back truck was not running. had a bit of trouble getting back started and i did but it was miss firing badley then died did not stay running. Im a 7 year tech and im beating my head against the wall. Tested for spark, no spark from any cyclinder. Checked relays/fuses they are all are good. fuel pressure good. crank sensor and coil pack good. however i did replace both just to see and still no spark. Hooked up scanner to the obdII inlet and no darn codes. any ideas im thinking pcm or cam sensor thats the only other thing i can think of. any ideas would help greatly
no one helped :(
I figured it out the ecm was bad the computer was smoking
